I heard the same thing, as long as you provide proof that you performed regularly scheduled maintenance outlined on page 7-11 for the items on pages 7-13 to 7-14 in the manual they should not deny warranty. Some things on the schedule do say "I" for inspect while others say "R" for replace. If you do your own oil changes you may have to provide receipts of the supplies, I guess.I was researching about maintenance and warranty and learned that the FTC has a policy on this. It is illegal for the dealer to deny cover because you had required maintenance done somewhere else. You must keep records. Kia's warranty manual states routine maintenance must be a reliable vendor and of a quality that matches Kia.
I was taking my 2007 Toyota to the dealership for routine maintenance but it felt like I was getting the "your at xxx amount of miles so we need to do xxx". And while that approach applies to some things, not all the things they were trying to sale me. They have been trying to replace my entire power steering housing ($1800) for years because it has a small leak during the hot summer months. I have never had to add power steering fluid.
I did my research and found a local mechanic (father and son) business that was established in 1979 and only hires ASE certified technicians. I took them my Toyota, I got a full report with pictures of what they were looking at under the car. I was blown away at the thorough explanation. They even prioritized the work with time lines from immediate to 9 months. I plan to trust them with my Telly.
I agree with @Butch Cassidy find a reliable mechanic.
Summary, other than a regular oil change and tire rotations/replacements, there are a lot of Inspects under 100,000 miles. Very few things require replacement while under the warranty period. If you do regular oil changes replace or clean the air filter regularly the only thing you have to really worry about is brake fluid at about 60,000 miles.
To replace as scheduled maintenance:
- oil and oil filter change every 7,500 miles
- "top tier fuel additives" every 7,500 miles
- cabin air filter every 15,000 miles
- air cleaner filter replace every 30,000 miles
- brake fluid every 60,000 miles
- spark plugs every 97,500 miles
- coolant replace at 120,000 miles then every 30,000 miles after
To inspect:
- drive belt inspect at first 60,000 miles, then inspect every 15,000 miles thereafter until it's time to replace
- batteries, brakes, refrigerant, shafts, boots, etc. all say inspect
- Automatic transmission fluid should never require service unless there is a problem in first 112,500 miles
- For AWD you have oil that needs inspection every 37,500 miles
Supposedly the AGM batteries are supposed to last 6-10 years while the conventional flooded batteries are 3-5 years.
