Memphisbaby3988
 - Apr 6, 2021
ETA showing 07-13 as of todayHi @StephenCantrelle , Could you check once more for an VIN: 5XYP5DHC9MG190239. Thanks!
Showing In Transit ETA 06-14 as of todayhi @StephenCantrelle can you check on 5XYP3DHC2MG187172?
Showing in dealer stock.. check with dealerCan you check 5XYP3DHC2MG187883 again? It was originally today but haven’t heard from the dealerThank you!
Showing In Transit with ETA of 06-22 as of today... Thank you for the beer money!Just checking to see if there are any delivery date changes to 5XYP5DHC9MG193139 initials JS. Beer money sent
First 2022 update*** breaking the Ice haha.... Your name is attached... ETA showing 06-24 as of todayStephen, any chance you can look up ETA on VIN 5XYP5DHC1NG196618. Thanks! Initials should be LH.
ETA showing 06-17 as of today.. just waiting to go In Transit up the roadAny update for 5XYP3DHC8MG193140? Thanks.
Your name is attached.. ETA showing 06-19 as of today@StephenCantrelle thank you first for your valuable info you provide. Can you please check for an ETA to MO003 for the following Vin # 5XYP5DHC6NG195948. should have initials NA. Thank you sir.
See right above.... another 2022... they are rolling at the factory@StephenCantrelle hello sir and thank you for the valuable info you provide. Can you please track Vin 5XYP5DHC6NG195948 going to MO003 and should have NA attached. Thank you again.
Dan
Your name is attached... ETA showing 06-12 in transit to dealer@StephenCantrelle. Can you look up 5XYP64HC3MG193604 for an ETA and if the initials TR are attached? Just sent tip via cash app. Thanks!
Showing in dealer stock... check with dealer..Hey Stephen! Do you mind checking vin 5XYPDHC1MG86220?
Thank you!
Hey Stephen! Can you track VIN # 5XYP5DHC1MG193202? Sending beer money now! Thank you.Showing in dealer stock... check with dealer..
Showing In transit ETA is 07-02 as of todayHey Stephen! Can you track VIN # 5XYP5DHC1MG193202? Sending beer money now! Thank you.![]()
Can you explain how this works. (Sorry, I am completely confused.) So, dealer says its not there. When something shows in the system that it is in dealer stock. Does it mean its there or in que to be there.Showing in dealer stock... check with dealer..
