cgriffith
- Feb 3, 2020
A couple of questions as I too want to access the reverse wire for my boat trailer with surge brakes.
Is the wire yellow or yellow/black?
Why didn't you splice into the yellow on the other side of the connector?
Thanks
Paul
I think it was just solid yellow, see pic. This is the harness that goes toward the hitch. If you go back to feb 5 pics, the problem is this is the right wire but does not go further out to the hitch after this connector. So, just cut it here and splice in the blue wire that comes with the kit. One of the pics, you see I just plug this wire into the trailer 5th connection. The kit comes with a five connector, but would be more trouble to replace the 4 connector at the hitch.
So all I used outta the kit was the blue wire.
