Does this look like there’s coolant in my oil?
the_system_is_down
2022 Telluride. Bought it in 2024 with 28k miles.
Since we bought it we have been dealing with slow loss of coolant. Level below L in the overflow reservoir can be seen every 5k miles or so.
I have topped it off twice in one year.
I keep looking for leaks anywhere but nothing. No coolant on the ground, no residue anywhere along the hoses.
Yesterday I did an oil change. Today the dipstick looks like this. What’s the consensus? Coolant in the oil yes, no?
Looks fine to me. Are you filling the coolant when the car is completely cool to the max lime?
I am filling slightly above middle after idling engine for 5 min. Slightly below F line basically.
I should note both times I topped off (one of those was yesterday) it was below L line after engine was up to temp.
Fill it to the max line first thing in the morning when the engine is completely cold. I had to fill mine as well. Seems to be air pockets in the coolant.
Short answer: NO
Longer answer:
Engine coolant and engine oil do not have emulsifiers to keep these dissimilar liquids homogenized. Therefore when cold, the coolant (water based) is heavier than the oil and will settle at the bottom of the oil sump (pan) with the engine oil floating above it. Just as salad oil and the vinegar will separate in a clear salad dressing shaker.
Furthermore the dipstick doesn't travel ALL the way to the bottom of the oil pan. If there's any coolant, you'll see it at the bottom of the glass jar after sitting on the bench for half an hour, unagitated.
We would normally diagnose such:
Place the car on the lift at the end of the day. In the morning, drain the oil out of the pan.
Service the oil and be sure to catch the first liter out of the pan, in the morning. Set the glass jar on the bench and walk away from it for half an hour. Come back and look for coolant at the bottom.
Many of us have seen the funky light brown (baby poo color LOL) coolant from a bad oil/water intermix online.
This comes about with larger amounts of coolant getting into the oil sump, then being churned into a mix (temporary mixing) by the crankshaft whipping it into a froth.
It does eventually separate and the above; first thing in the morning test will almost always ferret such out...
HTH?
Keep us in the loop.
