Garage opener lights on rear mirror telluride 2021
skloop
We have tried to find a place where we can illuminate the lights for our garage opener on the rear mirror. At night we have to turn on the accessory light to locate it. Can any help with this problem? The green light in the middle is lit but no others. Seems crazy that this is so hard to locate.
Those homelink buttons do not illuminate unfortunately. You can use the map light on the ceiling if needed to light up the cabin to see the buttons.
Thanks. With all the other bells and whistles, sure seems like a oversight for such a functional item. Appreciate the info.
We have 2 Garage Doors that are programmed to a Home Link Mirror. We use the Green Light as a Guide and know that our Garage Door on the Left is Left of the Green Light and the Garage Door on the Right is Right of the Green Light. Those programmable buttons do not light up.
That’s what I do too. Use the green light as a guide lol. Easiest way.
I just run my thumb across the bottom of the mirror to find the buttons at night. Super easy. No illumination required. Shouldn’t be hard even if you’re trying to find the second or third button.
