Heat at low RPMs
homerunbm33
Has anyone noticed their heat doesn't blow hot air when the RPMs are on the lower side(usually when stuck in traffic or at a light)? I can feel the temp change when I start to slow down or accelerate.
Iain
Our telluride is in the shop under warranty for this very issue as yet it is unresolved they changed the heater core but that wasn't the issue so we are in trial and error mode !
Weezee47
I'll be interested to see what the solution is. My wife just told me today that our Telly isn't blowing very hot air at 27.5°C... Going to schedule an appt to see what the issue is.
Tellthemride
@homerunbm33 This sounds like you experiencing the Idle Stop and Go feature of the car when you are at a complete stop in traffic. It's the gas saving feature that turns off the engine and keeps your accessories on (ie. radio) to save fuel at stoplights. Typically when the engine is off, the fan is blowing, but the AC and heat elements are off until the cabin's indoor temp starts to drift too far from the desired set point, and the engine will start up again to maintain the temp.
You can try pressing the Auto Stop button by the gear shift lever to see if this solves your heating issues at the stoplights and standstill traffic. Unfortunately, you will need to do this every trip you make with your car, since engine auto start/stop is enabled by default every time you start the car.
ucinn
Fairfield Township, Ohio
I turn mine off as it is now part of my start up procedure. It has now become natural motions. Our heat will down right melt you if not using the auto climate control.
homerunbm33
It is not the stop/start. I disable that every time I get in the car. This is happening at low RPMs/speed and when stopped in traffic(stop/start disabled and engine running). As soon as I start to accelerate you can feel the temp immediately change.
