Mass airflow sensor
Mike22
CRC GDI IVD cleaner is recommended for use in Kia vehicles. The cleaner is not made specifically for Kia vehicles.
beato1
Hmm, there's a good article relating to this: "Some manufacturers have also responded to fixing GDI issues by modifying their engine system, inserting a feature that allows it to spray a little quantity of fuel on the valves to prevent the accumulation of dirt. So if your GDI engine has this design, you don’t need to worry much. Just make sure you service your car at the recommended intervals."--https://rxmechanic.com/what-does-gdi-mean-on-a-car/
Another article: And this is consistent with the above article!
"GDI in KIA cars stands for Gasoline Direct Injection. GDI engines are different from regular gasoline engines, as they inject the fuel directly into the combustion chamber. The GDI system consists of a high-pressure pump that pressurizes fuel, which is sprayed via solenoid valves into the engine's combustion chambers. According to Hyundai Motor Company, its implementation of direct injection technology improves fuel efficiency by 10–15% and reduces carbon dioxide emissions by 5–10%.
The GDI technology allowed KIA company to provide cars that are much more powerful than the competitors and still very fuel-efficient. Also, these engines are usually quite long-lasting and don't require much attention when servicing a car.
On the other hand, not all direct-injection engines are as good. Some can be quite problematic. These are usually older models of cars, with the direct-injection technology implemented in the early 2000s. The most common problem is that they may have problems with soot accumulation on the intake valves. This leads to serious damage, so you should pay attention if your car has a GDI engine.
GDI engines are generally more expensive to produce and repair. However, if you buy a car with such an engine, it will save you money in the long run. Also, the direct-injection technology allows for much better fuel efficiency and cleaner emissions than other types of internal combustion engines. GDI is considered to be one of the most promising future technologies for gasoline engines that will be widely used in many years to come when it is already replaced with newer and better system."--https://cararac.com/blog/what-does-gdi-mean-in-kia.html
bills43
IMO - someone who doesn't know how to find a MAS, shouldn't be tinkering with a MAS :ROFLMAO:
It would have been quicker to google it than to sign up for an account to to ask the question.
Just what i was going to say..
