Motor Oil to Use
Alex915
Deland, FL
Owned a Highlander before my Telluride and used Amsoil oil on the Toyota. Amsoil does not have an oil that meets Kia’s requirements (got an e-mail from Kia on this). Kinda bummed out. Is Mobil 1 the only choice as a synthetic oil for the Telluride? What have others used assuming you have done the first oil change. Thanks!
RebelShadow
Pennzoil Ultra Platinum and Castrol edge titanium are the only 2 that I'm aware of with the Certifications for GDI engines. Personally I'm using the Pennzoil ultra platinum.
Alex915
Deland, FL
Thank you for the feedback. Any negatives on gas mileage or engine performance with the Pennzoil Ultra Platinum in your Telluride?
RebelShadow
no negatives, seems to run a little quiter and slightly better gas mileage by about 1 to 2 mpg on the average. I also noticed engine runs smoother compared to the factory OEM oil which is Castrol if I remember right. Castrol is still an excellent oil but noticed positive results with Pennzoil. Most reviews found Pennzoil scored slightly better as well.
TheNip73
Forgot to also mention that Pennzoil is cleaner. Believe the hype, Pennzoil base is derived from natural gas instead is raw crude so its cleaner to start.
Not apples to apples with the Telluride use case, but in my Volvo S60 I was using the Castrol. I recently switched to the Penzoil. In my used oil analyses the wear was lower with the Penzoil and my mpg increased slightly.
I’m a Penzoil convert. Planning to use it in the Telluride once received.
G
G-712363
Excellent!
Tino
Milwaukee
For your oil consuming pleasure.
bogie
Woodstock, IL
@Alex915 - can you share that email from Kia...?
TIA
djquestt
i ws told by dealer to not use synthetic for the first few oil changes, to wait to switch to synthetic, but when i took to my oil guy who researched it they said it was ok to use synthetic that just a trick dealers use to get you to come back for service
Vietvet
Western PA
My Dealer threw in 2 years of oil changes... so..I will ask when I get my first one... I put too much $$$$ into this vehicle to not utilize the manufacturer. If you think the Oil Service is a trick..have at it. Even in my older cars I have..I change every 3K. I can afford the oil and filter....better than a whole new motor. Your call. If I would have thought different...I would have bought a Chevy Cruze.... On sale now at a dealer near you.
JCzoom
I do my own oil changes. Mobile One oil, Kia filter. About $45-$50 total. Did my first change at 5K. Every 7.5K after that. I keep all receipts and record dates and mileage. I KNOW I do a better job than the under paid "oil techs" at the dealer.
I have done the same with my 2012 tacoma since new. 160K miles and runs like new.
JCzoom
Well, at my age...not climbing under a vehicle anymore. I believe in oil changes often..
Point taken. BUT, with today's oils and clean running engines, oil changes every 10K are the norm for most vehicles today. No benefit from doing more frequent oil changes other than maybe personal piece of mind. Enjoy your Telluride!!
TxAggie
Telluride Junkie
Katy, Texas
According to the owner's manual, under normal driving conditions the engine oil should be changed every 7,500 miles. I agree that this sounds like overkill with today's engine oils, especially the full synthetics. But I would rather follow the manual than risk Kia blaming an extended oil change interval for a failure...cheap insurance.
lyfbyts
I have went with using Amsoil at the Kia dealer 65.00 for the oil change started after initial breaking of 2K miles on the vehicle.
j0hne
Arlington, VA
Hey,
Got a PN for that OEM Kia Filter?
bogie
Woodstock, IL
Apparently @Alex915 has left the building with the info I was hoping he'd share....
