mrluckee
Hi, has anyone know how to view oil percentage in the screen(dash board), thanks in advance
I don't believe it has that feature. You simply set the service internal to the mileage that you want to do oil changes and it reminds you a few times as that mileage gets close.Hi, has anyone know how to view oil percentage in the screen(dash board), thanks in advance![]()
Yes sir an indicator level, like in My honda before , it will display in screen 15% oil life, once it turns to 0 %, will illuminate oil icon, need to oil change. Is the telluride has that one?I don’t think he was talking about the reminder, but rather an indicator for oil level.
Ours is reminding us with 3000 miles left, is there a way to set the reminder interval?
WOW Really, I had mine a week and thought it had this feature. A $50k car doesn’t tell you when the oil needs changing?? So what does the system check do? ThanksI don't believe it has that feature. You simply set the service internal to the mileage that you want to do oil changes and it reminds you a few times as that mileage gets close.
I found the maintenance info on the UVO app for my car and can set up the app to send me notifications of when it’s due. It’s doesn’t give you the % of oil used but it tells you how many miles until your next oil change. Question does the Telluride use synthetic oil? I’m assuming yes since the oil change is every 6 months.A $70K fully loaded Audi doesn’t have any oil life indicator either. You bring in your car for service at the recommended service intervals and you should be fine. The Telly reminds you when your service intervals are due. If you want to see how many miles/days have elapsed from the last service just need to change your instrument cluster menu to view the miles/days remaining until service is due.
Honda’s oil life indicator works on the same principal. Service due based on miles driven since last oil change. It’s not any kind of sophisticated quality sensor that can detect bad oil if that is what people here are confused about.
No, semi-synthetics come from the factory. You can use synthetics but this will not give you an increase in spacing.I found the maintenance info on the UVO app for my car and can set up the app to send me notifications of when it’s due. It’s doesn’t give you the % of oil used but it tells you how many miles until your next oil change. Question does the Telluride use synthetic oil? I’m assuming yes since the oil change is every 6 months.
