Orange Daytime Running Lights
Haus
According to all the press photos, the daytime running lights that come on the Telluride are orange / amber.
However, seeing the pictures of the Tellurides reaching the dealership, the daytime running lights are white.
To me, the orange daytime running lights were part of what makes it cool. Any info on why they are white and if they can be changed to orange? Is the SX Prestige trim orange?
Fortune
Tiffin, IA
im the opposite, i wish the SX got the white DRLs... apparently the dual beam LED headlight equipped models get the orange DRLs, and the standard single beam halogen headlight equipped models get the white DRLs... im not a fan of the orange, but oh well i guess...
Telluride Forum
Staff member
South Florida
Yeah, I think I prefer the white as well. There may be a way to change it with the aftermarket in the future...
Telluride Forum
Staff member
South Florida
Depends on the color of the car. If you get a white car, white lights would look better I believe. A black / darker car may look better with the orange lights, however.
Yeah, I was thinking that. The color of the exterior will make a difference. I think white would look best with white, black, grey...
Fortune
Tiffin, IA
im hoping for a yellow fog light upgrade in the future as well. i really don't want to put yellow film over the lenses...
i ordered black copper, so we shall see... im wondering if they stay on when the headlights/foglights come on or not...
tallLeRoy
Woodstock, Georgia
So my question now is which lights are on for low beams and which lights are on for high beams? I have not ever seen just one of the lights on inside of the orange position/turn signals. But I have seen those two lights on with the white light just below the orange position/turn signals. Are those the high beams?
What is on when parking lamps are selected?
LeRoy
Fortune
Tiffin, IA
LeRoy
They are dual beam LED low beams, with automatic high beams. Also the small light at the bottom of the housing is an LED as well, not sure if that's the high beam or what, but it can come on with all other lights illuminated, including the fogs.
OKIESXER
I don't care for the amber DRLs and don't see any way to turn them off in my owners manual. We have a white SX and also think the white DRLs would look much better, and we're getting no help from our dealership. Hopefully an after market fix or factory modification will be available in the near future.
Karam.31
Columbus, OH
Yeah that's the reason I don't like the white cause of the amber lights. I think they look much better with darker colors.
tylor
North Dakota
Not to be a Debbie Downer, but I highly doubt the amber DRLs will be changeable without cutting open the headlight housing and replacing the amber LED strip that circles the headlight. In this case, the amber DRLs also act as the front turn signal, so you would have to find a switchback-type led strip that is normally white, but changes to amber when the turn signal is activated. It would be an extremely difficult, if not impossible task. You may be better off swapping out the headlight housings all together for the halogen headlight and white DRL model found on lower trims, but then again the wiring harnesses and bulb connections are likely different.
Tim-in-CA
Sunny So Cal
Yea, it’s time to embrace the orange! At least those in the know that you sprung for the SX, but I’m sure mere mortals will not be aware.
