HillCountry
If you have time, you should produce a video of this test! I think it would be helpful to any owners who aren't sure of their car's ventilation performance.Follow up. I did the Kleenex test. I followed the instructions from my last post. First off. Set your a/c fan on high and therm to 65 degrees. Make sure your a/c vents are facing AWAY from the seat.
Next, I placed my hand to where I was barely skimming the seat cushion. As I moved my hand across the cushion, I felt a very, very, subtle layer of cool air coming up.
After that, I took a sheet of Kleenex, and placed it on the seat cushion, near the front. I then started to toggle the seat vent switch speed from 3-1 bars and kept toggling. As I was toggling, I did not take my eye off the Kleenex. I had placed the sheet near the front of the seat. As I continued to toggle the switch, the Kleenex started sliding from the front of the cushion to the back. I repeated this procedure several times. The Kleenex slid from front to back every time. So, it is a very slight airflow. Almost not discernible. Try that and see if you can repeat it.
