Radiator Cooling Fan comes/stays on.
TeedUP
I have a 2022 Telluride that just started having issues. When I turn off the car everything shuts down just fine, then after about 1-2 minutes the radiator cooling fan will come on at full blast. The car is locked without me in/near it. The only way for me to shut the fan down is to turn the car back on, but then it will just do the same thing once turned off. Right now I have the fan unplugged as it would run until my battery dies. And it's not because it's warm either, it's 38° here. TIA
I’ve had the exact same problem for over a year now. About to take it into the dealership for a third time after previously having them tell me the fan was faulty and replacing it and after they blamed it on the ADS, which they turned off. Neither of those solutions solved my problem. I am planning to just trade the car in and get a different brand. I’ve got a 2023, original owner and only 30k miles on it
i just had this issue pop up. I'm reading online that it could be a faulty temperature sensor or stuck relay switch. Were you able to diagnose it on your end or have it fixed? thanks!
