You've found the busiest Telluride community online!
Please register and become a member. We'd LOVE to have you! Please note: No advertising is permitted. None.
Rear rides low
Bradley King
Had my new SX with tow package for 5 days. Seems the rear sits about an inch lower than the front, without any weight in the back. Is this the norm? What about the auto-leveling?
jw_tx21
There is a discussion of the auto-leveling shocks in this forum - they work when the car is in motion. At a standstill, you may experience the rear-end being lower than the front.
cheeks80
As long as the shocks work when you actually drive and you do not feel it sagging you should be fine.
mrmac
El paso Texas
Yes, it is normal. When the training crew for the Telluride came to my local dealership, I inquired about this very thing. Kia said the design aids in reducing the drag coefficient. He called it "AERO OPTIMIZED." When I heard this, I had to research it. here is an excerpt from an article in Autoweek.
AERO OPTIMIZED “Low drag improves fuel economy, increases high-speed stability and reduces noise levels. So our designers gave the new Telluride a number of wind-cheating features to lower its drag coefficient − like the front-wheel air curtain that takes inair from an opening in the lower bumper and guides it across the front wheels to reduce turbulence. Then there’s the tailgate roof spoiler and ‘winglets’ at the side of the rear screen that improves aero. The result: an impressive 0.34 Cd.”
I use a leaf blower to dry much of my vehicle. I found that slope helpful when blowing from front to rear.
mrmac
El paso Texas
Please keep in mind, I am not an expert on drag coefficient, so he may have been blowing smoke, but it sounded reasonable, lol.
dba
Venice, California
I've been following this thread and decided I would chime in since my wife and I are experiencing the rear sag on our Kia. When purchasing a new car you don't expect to have to Google search a problem only two weeks after purchasing.
I purchased the Telluride SX, a beautiful car, but my wife and I have both noticed the rear sag on the vehicle. It doesn't fix itself or return to level as we expect it would. At first, we questioned if it was our groceries or putting anything in the back caused the sag but after driving around without anything we still see the rear sag 1 or 2 inches.
It doesn't matter if Kia claims "AERO OPTIMIZED." For a vehicle sagging in the rear, it's obvious that this doesn't look right and shouldnt be the experience a new user has. It's a shame that this early into owning a vehicle I would even consider returning it because of the rear sag.
Wap52
Black Copper SXP AWD Dune Brown with Towing
Terrell Texas
if the sag is the only complaint you have I would trade it away so another person can have your wonderful ride. The question is does it effect your driving or riding in the car? I know from my experience there is no way I let an inch or two sag make me get another vehicle but each to his or her own. I have the towing and i really like the way the self leveling works. One other thing , welcome to the forum and sorry you are disappointed in your new Telluride.
Telly
It is working as designed.
"The rear of a car with Nivomats may sag while parked because the Nivomat is mechanical and the vehicle needs to be moving in order for the pump to build pressure thus leveling the vehicle. It may take between 1-2 miles for the shock to reach its full effect. It’s normal for the vehicle to lower when not in motion."
hammick
So when the vehicle is stopped does the rear immediately go down? My aluminum trailer is hooked to the telluride now in on a flat surface. The trailer is not perfectly level but tilted forward just slightly. Wondering whether I should flip the receiver to raise the tongue or leave it as is.
dba
Venice, California
Not disappointed with the Telluride at all. But if I knew the vehicle would sag like an old Cadillac I wouldn't have purchased it. Vehicles are meant to be level not sag so this seems to me like a case of overengineering a product. When the Telluride starts selling in larger numbers Kia will either have to address it or be more public about the sag.
jw_tx21
In this thread, there are pictures that people took measuring sitting height with regular shocks and with Nivromats (on SX/EX with factory towing package only). Does your SX have the Towing package? Measure your height from center bottom of rear tire to car and see if it matches up with this thread and pics. If it's lower, you might indeed have some sagging issues. If not, then it's working as designed.
JCzoom
Who says vehicles are meant to be level? Most vehicles have some rake for a reason. Now, if you don't like the look, that is one thing, but its not a flaw of the vehicle. I actually think it looks good to have a slight rake towards the back. Thinking of putting front lifting springs in my Tacoma so it looks as cool as my wife's SX Telly. :cool:
JonFar111
Wisconsin
I have an EX with the factory tow package. After loading the cargo area my rear may be up to a 1/2” lower than the front. After driving it levels out. Sitting empty today the rear is 3/8” higher (32”) than the front.
