Telluride AWD SX GVWR?
titi
Washington DC
I am looking at buying a SX AWD (8 passenger version I hope...) for my business and take advantage of IRS's Section 179 6000-pound GVWR (Gross Vehicle Weight Ratio) one time deduction. On Kia's Telluride specs page, the EX AWD 8-passenger is rated at 5,917 lb. GVWR. The SX AWD 7-passenger shows 5,736 lb. which is a bit surprising. I would think the two second row captain chairs would weight more than a 3-pers bench seat and with the added second sunroof on the SX the GVWR should be right around 6,000 lb? Technially, the IRS goes by the GVWR label on the driver's door. I'd be curious to know what the label actually says compared to Kia's posted specs.
Dandy
Minnesota
I doubt it will make it. I am in the same situation. I would prefer a vehicle with a 6001+ GVWR but it seems that in this class, that isn't much more. My current Flex is 6250. The Subaru Ascent is 6000 so it is 1 pound shy of qualification. Hopefully my comment will bump this up and someone can comment with the GVWR on the door panel. I have read that if it is indeed over 6000 pounds, the vehicle classification changes within the government causing the manufactures some additional issues. If this is true it would explain why car companies that have trucks will have other types of vehicles over 6000 lb GVWR as they are already accustomed to the other hoops they must jump through.
By the way, I don't believe there will be (at least 1st year) SX with 8 passenger configuration. For some reason, many of the manufacturers in this segment are not having a 2nd row bench in their top tier options.
titi
Washington DC
Good thoughts. I am actually interested to learn how the Section 179 tax write off works. Do you just tell your accountant you acquired an over 6,000lbs vehicle for the company? Does the IRS require some paperwork to confirm that the vehicle is over 6,000lbs?
Dandy
Minnesota
I am not an accountant. This is a source I found. Not sure how accurate it is to current tax law, but it coincides with what my account has said. My last few company vehicles my accountant had me email him a copy of the plate/sticker in to door jam that states the GVWR with the VIN and such.
70camguy
My SX-P AWD w/ Tow Package has a GVWR of 5917 Lbs on the Door... I did notice that Kia's Site says 5736... Wondering if the Tow Package makes the difference??
Average Joe
So, the SX with 2nd row bench seat should exceed the 6000 gross vehicle weight ratio ((GVWR) due to the weight of the additional passenger, correct? If so, why can’t it be ordered that way?
