Telluride no A/C
Cjohnston
Well I've had my Telluride about four months and it's back in the shop for the second time. First to replace faulty gaskets in the differential and now the A/C doesn't work. It will blow cold for 15 minutes and then blow hot. I was told it's most likely a faulty compressor.
ernysan
Please keep the post until they solve your issue and let us know the details thanks for share and hope you get your ride SOONNNN
Cjohnston
Update: Apparently the system was overfilled with freon. This caused the system to shut down and the compressor to freeze up. The system was "evaced" and refilled to the correct level. As of now it is cooling properly.
Cjohnston
Second update: It's back in the shop and they don't know what the heck is wrong with the A/C.
Cjohnston
Third update: I was told it has a bad compressor, which is what was suspected originally. Of course parts have to be ordered. So, faulty gaskets on the differential and a bad a/c compressor, but who's counting. I never had a problem with my KIA Borrego.
