Tpms issue
c.hanky
Looking to see if anyone has come across tpms issues? I had a low warning come on for L/R on a cold night with the said tire being 1psi lower then the others. Adjust all to 32psi. The car is reading the the correct pressure. Warning will not go out. I can’t find anything in the manual for a reset procedure. I will be booking it into the shop. Thanks for any input.
Frankie Knuckles
Has the car been driven since the tire was inflated?
Good point! The car must be driven in order for the TPMS to calibrate to the current tire pressure.
c.hanky
Thanks for the replies. It has been driven multiple times city and highway. It’s clearly reading the pressure as I can see the pressures go up a couple psi with temp. Almost makes me think it could be a software issue. This is my first Kia and not sure if they are known for software issues.
