TSB 199 202003 - Rear Washer Nozzle Improvement
bogie
Woodstock, IL
TECHNICAL SERVICE BULLETIN
SUBJECT: REAR WASHER NOZZLE IMPROVEMENT
EDIT: 05/26/20, Attachment replaced with Revision 1. This revised bulletin changes the applicable build dates to February 6, 2019 (previously April 1, 2019) through October 28, 2019
TheNip73
Not sure I would want them to do all of that work for a little washer fluid leaking.
Probably paranoid, but not a fan of trim removal unless absolutely necessary. Tech breaks a clip, doesn’t care, not his/her car and puts back together. Your now the owner of a rattle...
alexdrums
Phoenix
This bulletin applies to build dates April 1, 2019 through October 28, 2019
Wow, that is a lot of work for a tiny nozzle!
MarcinTexas
I assume this means the newer models have this fix already installed. Can anyone confirm with a build after October 28, 2019?
WhiteSX
New England
For those paranoid about your dealer doing the work, the check valve ass'y is available from Kia. MSRP: $2.50 Part# 9888634000 FFF
Seems simple enough for a DIY project.
Enjoy the ride.
TheNip73
Feb 4 build date - have not noticed a lot of water coming out after spraying - just a few drips. I doubt that a solution with zero leakage is cost prohibitive.
earlgrey
Had this fix done when car was in the shop for the rear hvac tsb. Looks promising. No washer fluid streak yet on rear window.
bogie
Woodstock, IL
Orig post updated as indicated...
