Valet Alert!
MELISSAB
2020 EX Everlasting Silver
We only have the two fobs, no other fobs or keys that I know of. I checked the app and there is a logo of a green guy with a exclamation point. I touched that so it isn't green anymore but I don't have any geofences setup, so I don't know why it would think I left a certain area. It's been doing this since we picked it up. Hmmmmm???
TellurideSX
Then valet alerts should be presented with an option to toggle off, but hitting the green guy off should have done the same thing.
MELISSAB
Bingo, the green guy is the culprit! There isn't any indication on the screen what the green guy does before or after so I must have hit it one of the times I was trying the remote start. Thanks for pointing out the My Car Zone section of the app. I hadn't seen that section so of course that's where I needed to be. I figured there had to be a place to set up a geofence for something like that to work and kept clicking the locations button but couldnt do anything at all in that section. Once ya'll pointed out the My Car Zone part I can see where you can set up a geofence but there weren't any there, so still a mystery why it was alerting. Hoping it stays turned off. Appreciate all the help!
Langelic
Thanks for your help with this as I was receiving "Valet Alert" as well. As suggested, I went into the Kia UVO Access App and went to the My Car Zone section and toggled Valet Alerts to Off
Jasondorin
I had the same issue but had to resolve it on kia.owners portal which you have to access via your browser. Same log in. In there there are ton of settings. Just make sure valet is off.
Gravity Gray
Hi all- glad I found this forum as I’ve had the same problem with the valet alert. I turned it on with the UVO app to try it out and I’ve turned it off, but still get the alert constantly on my infotainment screen.
When I go to My Car Zone and tinker with adding a new alert, Valet alert is grayed-out and can’t be added as a new alert- even though the toggle switch shows that the Valet alert is OFF.
Frustrating! Loving everything else about my new ride but would love to get this problem solved! Any further ideas?
Many thanks
