Speedometer
Jewel
My Telluride is a few weeks old and noticed that the speedometer and the digital speed is about 3-4 miles off. Has anyone else had this issue?
you mean there's a mismatch between the mph on the Head-Up Display vs. the analog gauge?
I wish I could tell you but I only look at the road and the HUD when I'm driving.
I haven’t noticed a mismatch. Have you set the cruise and then verified a mismatch?
My speedometer could read 50 and the digital will read 47.
I had a similar experience. I set the cruise control to a set speed then opened up my Waze app to see it was off by 1-2mph. I was going slower than the cruise control said I was. The speedometer will be the most accurate as I think it uses the revolutions of the hub. But depending on your wheel with tire height, the other computerized speed measurements may be off a little and change as the tires wear down their tread. I’m okay with it because I was planning to shop for my next set of tires hoping to get close to 1” taller.
you mean the Head-Up Display vs. the analog gauge?
maybe the analog hand on the speedometer is misaligned? That doesn't seem like a difficult fix.
I'm bringing it in on Friday to address it. Apparently others have had similar experiences. I think it is a simple reset. I will post the outcome. Happy new year!
AWD or FWD?
Normal on my car but only about 2MPH. I have a GPS app on my phone and ran it when I was driving. My digital readout was more accurate than the analog gauge. Try the same thing and see which is more accurate for you and trust that reading.
