What TPMS did you buy
Which sensors are you guys using for aftermarket wheels if you’re not using the stock ones? Any brand better than others, and part numbers would be appreciated. Thanks in advance!!
Part #: 52933-C1100
I've read somewhere Schrader is oem supplier for KIA, but I can't verify that info right now. Amazon has a set for $89 and Ebay for $60. I have a set coming from Ebay and plan to put my winters on this Saturday so I will find out.
Sorry to report back so late. Shrader TPMS works well. It took a bit to relearn the sensors, but eventually it synced.
Did the vehicle relearn the sensors or did you need a separate device like a relearn tool?
Not sure if Costco reset anything, but it worked after couple hours. It gave me TPMS system error on the dash once right after install, but gone away after restart.
