Crossbar broken bolt
Chizadyo
New Jersey
Hello Telly family,
Finally had a chance to install OEM crossbars this afternoon. Following instructions to torque bolts down at 53 ft lbs. 1 bolt snapped so I called local dealership asking for replacement. Unfortunately kia doesnt sell the bolt separately from crossbar assembly, dealership is calling corporate for a replacement. Does anyone have any info on bolt size just incase kia won't provide replacement bolt? Thanks in advance.
I don't have an answer for you, but try taking a good bolt to a local hardware store. There should be a common metric bolt that will fit.
That's the plan if local dealership cant assist me out. It's hard being patient with dealerships!
Have you taken the bolt to the dealer? They may have a non-specific spare one that will fit.
Thanks that's a good idea, I'll contact them tomorrow.
I would match one up from a hardware store unless these are special KIA bolts which I doubt
53 foot pounds is like 635 inch pounds.....gotta be a typo 😂
Sure it was ft pounds not inch pounds?
Yes you are correct 53 lb. In... Either way I set the Torque wrench to 6 N.M, the bolts tightened but continued to spin. Their secure I just wish they capped out once Lb.in or N.M was reached.
I just broke one of my bolts on my OEM crossbar trying to tighten to 53 ft lb. I tightened the other 7 bolts to about 20 ft lb and stopped. I'm going to get a replacement bolt and get it fixed before I use them. I see my error now that the units are different (ft-lb vs in-lb). I'm also going to loosen the other 7 as they are way to tight.
did we determine what the correct torque spec is?
