- Mar 7, 2019
Woot Woot!! Thank you!Thanks Stephen. Sent some tips.
Thank youETA showing 03-27 as of today
No name is attached. so that is normal if you put a deposit on one already assigned to dealer. If you did a custom order than this isnt the one. ETA showing 04-24 as of todayHi! Can you track my vin and confirm initials are RC?
5XYP5DHC4MG174031
Thank you, venmo tip incoming!No name is attached. so that is normal if you put a deposit on one already assigned to dealer. If you did a custom order than this isnt the one. ETA showing 04-24 as of today
Awesome! Thank You!Thank you, venmo tip incoming!
In Transit to dealer... ETA showing 03-21 as of todayHello, Can you track my vin please?
5XYP5DHC3MG167667
Thank you!In Transit to dealer... ETA showing 03-21 as of today
Thanks Stephen. Just called the dealer and they said it wasn’t in yet. Guessing it will show up someplace in the next few days.Showing in Dealer stock.. check with dealer
Yes it happens sometimes... should be there is next couple daysThanks Stephen. Just called the dealer and they said it wasn’t in yet. Guessing it will show up someplace in the next few days.
Name is attached... ETA showing 04-18 as of todayhello Stephen can you please track 5XYP5DHC5MG173664 intial should be HP. thank you
thank you sorry double checking Initials are HP?Name is attached... ETA showing 04-18 as of today
Yes has your namethank you sorry double checking Initials are HP?
thank youYes has your name
Your name is attached... ETA showing 04-18 as of today
Thank you so much, super psyched to get my Telluride!Your name is attached... ETA showing 04-18 as of today
@JoCip did you get your Telly? Mine was due in 3/17 I was just curious how fast or slow your transit time was?@StephenCantrelle can you please check on VIN 5XYP5DHC8MG164831 and see if the order is for initials JC? If the initials match what is the status and ETA? Thank you.
