LookingforTelly
- Apr 4, 2021
On the left side of the steering wheel, you can switch between audio inputs, radio/Sirius etc. Then if you want to change stations you have to hold the toggle switch up and down. If you push it just once, it toggles to a different input. This is super annoying and as I'm skimming through channels I end up switching to a different input more often than not.
Can I fix this? I find the mode button adequate, I'd like to be able to use the toggle just to flip one channel at a time. I don't need 2 separate input buttons.
