Clock ?
AK Telly
Is there a way to turn OFF the screen display, but still keep the time display ?
Yes.
14.10 or before: setup > display > screen saver, then choose digital or analog clock. Then turn off the screen and it’ll be blank except for that readout you chose.
15.0: setup > screen theme/layout > screen saver, again choose digital or analog clock.
Thanx, I'll try that.
What's the 14.10 & 15.0 ?
Map update/software versions. This is assuming you have the 10.25” infotainment display.
The only way you would have 15.0 is if you performed an update yourself in the last two weeks (it released April 12). Otherwise, you have 14.10 (purple/neon appearance) or earlier (classic-looking appearance).
I’m just seeing now that it looks like you have an LX, so my direction may not be of any help to you. The 8” infotainment is totally different.
