Track my vehicle
ETA showing 05-23 as of today.. Don't see a name attached
Edit *Every Vin I looked at isn't showing a Vin.. would not surprise me if update happened not allowing me to see names attached now
Thanks. Tip sent via Venmo. I reached out to my salesperson asking for update on VIN. Will let you know if it is mine. Fingers crossed it is and that the ETA will hold true.
How do we know when an order has been accepted?
I ordered on 3/9, no VIN on Failcat yet. Checked with dealer and they confirmed I'll still be getting a '21, so I assume it's been entered into KFOS by now...
Edit *Every Vin I looked at isn't showing a Name.. would not surprise me if update happened not allowing me to see names attached now
Hey @StephenCantrelle I think it might finally be my lucky day. What I think is my VIN just popped up on failcat. Can you please confirm my name is attached CW and ETA for 5XYP5DHC1MG187125
Thanks so much.
I knew my dealer had 2 coming. Didn't know they would be exactly the same. 2nd VIN popped today. Will you please check if you see a name and if these will show up on the same ETA?
2nd VIN is 5XYP5DHC6MG187413
@StephenCantrelle
We were told the ETA would be 5/15. We're curious if there are any signs of it coming early. Mind checking?
5XYP3DHC3MG180974
Showing In Transit to dealer with ETA 05/15 as of today
If dealer said you are getting a 21 then it must be already in KFOS.. and just waiting to be built and generate a Vin number.
ETA showing 05-23 can not see a name attached
What's the typical timeframe for KIA to start building an order that's been in KFOS?
Thanks!
Hi @StephenCantrelle
Do you have any info on 5XYP5DHC2MG187442 in terms of ETA? I was told by my dealer potentially June 5th, but I just wanted to confirm.
Thank you!
Hi @StephenCantrelle -Any way to see if this vin is a customer order or potentially dealer stock? 5XYP5DHC5MG187449
Thank you!
ETA showing 06-05 on my end as well... as of today
I see a name attached
Stephen
Any ETA on 5XYP5DHC9MG176566
Dealer initially said delivery would be 4/27/21 but now not able to get updates.
thanks in advance!!
Update from my dealership the 2nd VIN is mine tentatively. They actually have three of the exact same one coming. Names not attached in system as they are going by priority and deliver. I am first in line. If they show up on different dates I will get whichever one is first available. 😊
