 - Mar 7, 2019
No name attached which is normal if you put deposit on an incoming unit already assigned to dealer...Thanks! Does it show my name (initials KO) attached?
Yep, that’s what I did. Thanks so much!No name attached which is normal if you put deposit on an incoming unit already assigned to dealer...
Showing In Transit to dealer with ETA of 06-07 as of today
Stephen - could I get an ETA update on this vin? Vehicle in transit?
5XYP5DHC9MG176566
In Transit to dealer... ETA showing 06-06 as of today@StephenCantrelle what you're doing here is amazing. Can you check the status of 5XYP5DHC7MG185931 should have the initials NM attached to it if it's ours. Have a lease ending on a current vehicle and hoping the timing works out. Had an estimated 6/5 arrival at our dealership.
Thanks
Showing In Transit to dealer 05-25 is the ETA as of todayHi @StephenCantrelle , can you please check VIN 5XYP5DHC9MG185459? Initials are JS. Thanks for what you do. I’ll get some beer $ headed your way.
No we typically see it a day before Failcat.. This has your name on it if I am reading your user name correctly.. R*** C********.@StephenCantrelle as others have said, thank you for everything that you are doing.
Could you please check VIN 5XYP64HC2MG188202?
Also, the dealership is saying that they do not have the VIN in their system yet, but just the order details. I pulled this from Failcat last weekend.
Is that common for them to not have a VIN when Failcat does?
Again thank you.
ETA showing 05-25 as of today
Your name is attached. ETA showing 05-29 as of today.@StephenCantrelle : Can you please check this VIN: 5XYP5DHC0MG189190 , Initials: SS
I've venmo'd you a little appreciation for your awesome contribution here![]()
It shows up in the website when they "Invoice to dealer" basically when they are about to ship out from plant. Time will differentiate by distance from factory to dealer.. can be days to weeks.Hey @StephenCantrelle. How long after cars are added to dealers inventory do they typically show up on the lot?
Has different initials attached..Hi @StephenCantrelle could you check this vin 5XYP5DHC5MG190190 initials JS. This is the vehicle and dealership I ordered from but it has a bunch of accessories that I didn't order so I'm unsure if it's mine.. Thank you
ETA showing 06-13 as of todayCould you please track my Telluride? The dealer says it scheduled to arrive at the Kansas City dealership on June 15. Vin is 5XYP6DHC5MG187495
