 - Mar 7, 2019
Your name is attached.. ETA showing 06-19 as of todayGood morning Stephen. Can you check on a ETA for VIN# 5XYP5DHC9MG191410 Initials KE?
ETA showing 06-10 as of today
Thanks so much for checking for me. Really appreciate itYour name is attached.. just waiting to go IN Transit... ETA showing 05-30 as of today
Showing in dealer stock.. need to check with dealerHey @StephenCantrelle could you please check this one final time it was supposed to be deliver to the dealer today (according to the last ETA) but they haven't returned my call 5XYP5DHC9MG185526 initials RP - thanks !
Your name is attached! ETA showing 06-18 as of todayHi @StephenCantrelle would you be able to check if a name or initials (LD) are attached to VIN 5XYP6DHC7MG190835 ? Thank you!
Your name is attached... ETA showing 05-30 as of today.. just waiting to go In Transit@StephenCantrelle could you kindly check 5XYP64HC2MG188202 for status/ETA? Should have RC initials.
Thanks in advance.
Thanks @StephenCantrelle I placed the order in mid April and the dealer 100% guaranteed that it would be a 22 model. Now I'm torn do I take delivery or wait to see how the 22 model will differ. I guess the dealer would have to put me back into the queue and it would be at least another 2-4 month wait.Your name is attached! ETA showing 06-18 as of today
ETA showing 06-08 as of today. don't see a name attached which is normal if you put a deposit on an incoming Telluride already assigned to dealerHi Stepehen, Could you please check 5XYP5DHC8MG190295 for ETA initials RN should be attached. Thank you so much!
Showing 06-12 as of today.. in transit to dealerHey @StephenCantrelle - Can you track VIN 5XYP5DHC4MG190164 again to see if the date has changed? I'm going to try to make some "advanced plans" for getting to PA if I can, knowing the ETA may change. I just don't want to be in the position of booking a same day flight if I don't have to.
Thank you again sir!
Thank you sir! Do you think it's safe to plan on that day since it's in transit or should I still wait to make travel plans?Showing 06-12 as of today.. in transit to dealer
Best to wait.. these ETA's move quite frequentlyThank you sir! Do you think it's safe to plan on that day since it's in transit or should I still wait to make travel plans?
Got it! Thanks again!Best to wait.. these ETA's move quite frequently
Showing In Transit to dealer...ETA is 06-24 as of today@StephenCantrelle can you check on my ride? The VIN is 5XYP3DAC6MG191631. Thanks!
