Track my vehicle
Could you please track VIN for me? Should have my name or my husbands attached to it. Thanks! Will send beer money!
5XYP6DHC9NG196086
5XYP6DHC9NG196086
ETA showing 07-05 as of today... need initials to check name... don't want to post full names on a public forum
Could you check on a VIN for me? initials should be NP, will be sending beer money!
5XYP5DHC0NG196058
5XYP5DHC0NG196058
Your name is attached... ETA showing 07-15 as of today
ETA showing 06-18 as of today.. just waiting to go In Transit to dealer
thank you!
Could you check 5XYP5DHC9NG195958 for me please. The initials should be ML. My other question is how are VIN numbers read now other than the last six numbers?
Your name is attached.. ETA showing 06-26 as of today.. If you scroll up a little you will see that the front part of the VIn varies after 5XYP.. I also need the full vin if a Telluride is marked sold.. I can see when it was sold and can help people who may have had Telluride sold to other people(It happens)
I thought I gave you the full VIN number 🤔. il attach it again here sir. The breakdown of VIN number used to have the first digit for where it was manufactured like a 1 meant United States, 2 meant Canada and 3 meant “other.” I thought there was a method to break these VIN numbers down too. Thank you sir.
Oh sorry think we just had miss communication is all.
Yes the VIN breaks down just like a social security number..
Copy and pasted this from AutoZone
World Manufacturer Identifier
The first three digits of a vehicle’s VIN make up the World Manufacturer Identifier (WMI).
  • The first digit defines the country of origin or the final point of assembly of your vehicle.
  • The second digit indicates the manufacturer and the region where your vehicle was produced.
  • The third digit, when coupled with the first two digits, indicates your vehicle’s type or manufacturing division.
Vehicle Description Section
Digits in position 4 through 9 make up the Vehicle Description Section (VDS).
  • The fourth through eighth digits describe your vehicle’s model, body type, restraint system, transmission type, and engine code.
  • The ninth digit is the check digit, which is used to detect fraudulent VINs. The number that appears in the ninth position varies and is based on a mathematical formula developed by the U.S. Department of Transportation.
Vehicle Identifier Section
Digits in position 10 through 17 make up the Vehicle Identifier Section (VIS).
  • The tenth digit indicates the year, which only applies to vehicles built in or after 1981 since the VIN format was not standardized until that year.
