If your Telluride is so loaded that your rear bumper is within 2.5" of the ground, you've got bigger problems.Is there any issue with aftermarket hitches and ground clearance when loaded since the aftermarkets hang below the bumper lower than the OEM?
Potentially, yes. You already knew that. My aftermarket unit, Curt, is not as tucked in as factory unit. Hangs down at least 1” more, to my disappointment. However, my AWD drive unit is already lacking ground clearance as built. Offroad travel will be risky if you venture beyond fire roads and sand washes. Hence, not that concerned about hitch height.Is there any issue with aftermarket hitches and ground clearance when loaded since the aftermarkets hang below the bumper lower than the OEM?
I was more concerned with when hitting bumps, speed bumps, or even pulling out of my driveway where it has a rolling curb so I definitely get some bounce. And the lower hang would hit the road.If your Telluride is so loaded that your rear bumper is within 2.5" of the ground, you've got bigger problems.
Follow up on this. The $500 is for the hitch only. The 7-pin connector and installation totals about $1,000. The sales person gave me wrong info 5 weeks ago.My dealership (Oakes Kia in Kansas City) will install the hitch on my Telluride S trim for $500.
That's seems like they don't want the business unless you overpay.Follow up on this. The $500 is for the hitch only. The 7-pin connector and installation totals about $1,000. The sales person gave me wrong info 5 weeks ago.
Thank you very much 2020Telly for this info. It's very helpful. Now I know exactly what parts are necessary. I know someone with experience that can do the install, probably for about $80. Once I get the parts, I'll get them to him and he can do it.That's seems like they don't want the business unless you overpay.
Parts
Labor
- There are online dealers that will sell you the hitch for under $385. S9F61-AU000 - Tow Hitch - 2020-2021 Kia Telluride | Wholesale Kia Parts
- The bumper cover for $40 S9F61-AU060 - Tow Hitch Chrome Cover - 2020-2021 Kia Telluride | Wholesale Kia Parts
- The 7-pin harness for $137 S9F67-AC500 - Tow Hitch Harness 7 Pin - 2020-2021 Kia Telluride | Wholesale Kia Parts
Sounds like the dealer is implying their installation is valued at $400/hr. I'm in the wrong business especially since they are still making money on the parts.
- The DIY job takes maybe an hour, so without any installation you can do it all for under $600 (tax not included)
- UHaul only charges $142.50 plus tax for installation.
- I would think you could buy the parts and go to a camper dealer and all in spend under $750.
If you have a 2021-2022, just don't forget that if you plan to tow something with a 7-pin you will still need a electronic brake controller. If you plan to tow something with a 4 or 5-pin flat you are fine but you still need an adapter to go from the Kia 7-pin down to a 4 or 5. This is what I mean: Amazon.com: WOFTD Trailer Plug Adapter 7 Pin Flat Blade to 4 and 5 Round Trailer Connector Trailer Adapter 7 Way to 4 Way 5 Way 2-in-1 Flat Blade Plug: AutomotiveThank you very much 2020Telly for this info. It's very helpful. Now I know exactly what parts are necessary. I know someone with experience that can do the install, probably for about $80. Once I get the parts, I'll get them to him and he can do it.
Parts
Labor
Very helpful thread. Has anyone gone dealer route and been happy with it? I am tempted to go with dealer for bumper integration and height.
