Track my vehicle
Hi @StephenCantrelle - hoping you can check the status of my Telluride, if possible. VIN: 5XYP5DHCXNG197542. My initials are LR. Thanks so much!!
Hello @StephenCantrelle can you check the status of my Telluride? VIN# 5XYP6DHC9NG198243. Thank you so much!! My initials are KH!
Your name is attached... ETA showing 07-06 as of today
I see different name on this one which is possible if you put deposit on one already assigned to dealer(maybe someone backed out) This isn't a custom order in your name if you did that... ETA showing 07-16 as of today
Thanks so much for the update. I had the same order the dealer was to place (plus a couple accessories) but they had someone back out, so offered this to me to save a couple months and will install the accessories once received. Truly appreciate it!
Hi @StephenCantrelle! Can I get an ETA for this Vin 5XYP5DHC2NG200238?
Hi @StephenCantrelle if you don't mind, can you confirm initials RH or DH are connected to VIN 5XYP5DHC8NG202205, and provide an ETA if available?
Thanks in advance for your help, and all of your contributions to the forum!
@StephenCantrelle This it’s so much work on your part, I am amazed and impressed with how hopefully you are to all of us on this forum. I would think it would be a real burden at times. I truly hope people show their gratitude every time you help them!
There are several ways at the bottom of his profile signature. I don’t know him personally and he did not ask me to do this. He helped me And I really am grateful for him in this group!
Hi Stephen,
Could you please check Vin 5XYP2DHC5NG200839 whenever you have some time, initials PK
Thank you for the help 🙂
RH is attached and showing ETA of 07-10 as of today
Hey @StephenCantrelle, Can you please confirm CY is connected with XYP64HC6NG202135 and ETA date. Thank you for all your help!
I see a different name on this so isn't a custom order for you.. If you put a deposit on one already assigned to dealer then that will explain why as it may have been someone who backed out... ETA showing 07-29 as of today
