@StephenCantrelle would you mind checking this VIN for me? Should be initials NW or DW. 5XYP5DHC7NG201725.
Hi Stephen,Sending you some beer $!
NW is attached... ETA showing 07-06 as of today@StephenCantrelle would you mind checking this VIN for me? Should be initials NW or DW. 5XYP5DHC7NG201725.
EP is attachedHi Stephen,
I forgot to ask if my initials EP or LP were connected to the order. Thanks!
VIN: 5XYP5DHC8NG198172
Your name is attached... ETA showing 07-06 as of todayHello @StephenCantrelle can you check the status of my Telluride? VIN# 5XYP6DHC9NG198243. Thank you so much!! My initials are KH!
I see different name on this one which is possible if you put deposit on one already assigned to dealer(maybe someone backed out) This isn't a custom order in your name if you did that... ETA showing 07-16 as of todayHi @StephenCantrelle - hoping you can check the status of my Telluride, if possible. VIN: 5XYP5DHCXNG197542. My initials are LR. Thanks so much!!
ETA showing 08-03 as of today@StephenCantrelle, thanks for all your time and effort! Could you check the status of VIN 5XYP5DHC3NG202032? Thanks.
Thanks so much for the update. I had the same order the dealer was to place (plus a couple accessories) but they had someone back out, so offered this to me to save a couple months and will install the accessories once received. Truly appreciate it!I see different name on this one which is possible if you put deposit on one already assigned to dealer(maybe someone backed out) This isn't a custom order in your name if you did that... ETA showing 07-16 as of today
Check with dealer showing in dealer stockHi @StephenCantrelle! Can I get an ETA for this Vin 5XYP5DHC2NG200238?
RH is attached and showing ETA of 07-10 as of todayHi @StephenCantrelle if you don't mind, can you confirm initials RH or DH are connected to VIN 5XYP5DHC8NG202205, and provide an ETA if available?
Thanks in advance for your help, and all of your contributions to the forum!
I see a different name on this so isn't a custom order for you.. If you put a deposit on one already assigned to dealer then that will explain why as it may have been someone who backed out... ETA showing 07-29 as of todayHey @StephenCantrelle, Can you please confirm CY is connected with XYP64HC6NG202135 and ETA date. Thank you for all your help!
