2 beeps maybe from radio -why?
Jennj
We have had the telluride about a month . Drove a long way with it and now doing anothe rlong
Long road trip and once in awhile we get two beeps - maybe from the radio? No idea why. Does anyone know ?
Low fuel indicator?
No. We have a full tank of gas . At one point the 2 beeps were going off every 10 minutes but we took my cell phone out of the place where the phone gets charged since it was fully charged and wonder if that is another signal .
If you had the adaptive cruise control and highway driving assist engaged it will beep if it adjusts speed according to changing speed limits. Perhaps that might be what you’re hearing.
Or crossing over lines with lane keep assist on with out signaling?
I had this a week ago. I suspect it has something to do with the phone charger being plugged for too long (I was charging my phone as I was using it for GPS). My (unfounded) theory is that since the 12V socket is destined primarily for the cigarette lighter, it might be a warning that your lighter's been pressed for too long and might be too hot. But that's just my guesswork
Are you driving while this happens? The system will also beep if the vehicle is on but engine is not running to warn you about battery drain.
Every now and then my EX will beep (not sure if its once or twice). When I look down to the instrument cluster I saw a message that says something like 'Might need to take a coffee break' and even has a small cup of coffee by it. This happens usually on long trips. I really don't know why unless it just doesn't like the way I drive.
I got it every 20 mins after a few hrs of driving. Supposedly, it detects your alertness and warns you, which based on my experience was very accurate. I wasn’t sleepy but did feel tired and not moving my eyes as much. Decided to turn it off.
I've nearly wrecked trying to find how to turn off my alertness warning when I first got the car. Talk about irony 🙄
i bet you stayed alert for the rest of the drive 😁😁
Whenever I hear these beeps it's when I'm adjusting the cruise control and the speed is the same as the actual posted speed limit. I usually drive 10-15 over but on some occasions I at least pass through this speed as I'm adjusting up.
I kept hearing a beeping the other day. At first I thought it must be the radio, but I turned that off and still I heard the beeping.
Finally, I realized I was going 40 in a 65 zone with a double yellow no-passing line and the guy behind me was getting ticked! 🤠
Hmm… maybe the HDA system that only works on major roads?
Ours beeps whenever we pass through an intersection with a traffic camera -- to let us know that we're now "under the radar". Not sure where the setting might be to enable or disable this.
I went through all the vehicle setting and don’t remember seeing the setting. You can try the gps setting. That’s where I turned the traffic camera off in my other cars.
