@StephenCantrelle Thanks for all you do! Would you mind tracking vin number 5XYP34HC3NG209147? Initials should be CJ or JJ, I believe.JG is attached to 135... ETA showing 07-10 as of today,, is in transit to dealer
ETA showing 09-12 as of today
DR is attached... ETA showing 08-17 as of today5XYP64HC3NG209575. RR or DR. Can you please give me an ETA? Thanks
ETA showing 08-26 as of today@StephenCantrelle good morning was hoping for an update on 5xyp5dhc0ng204675 its so close the wait is almost over. tip to follow of course thanks again for everything!
Dealer has marked it sold today so can no longer track... still has your name attached..@StephenCantrelle can you please check the ETA on 5XYP5DHC4NG205201? Is it still 08/21??
thanks in advance
ETA showing 08-18 as of todayGood morning and Thank you in advance for all the help you provide the Forum @StephenCantrelle can you please check this VIN for me? 5XYP5DHC8NG209512
Should be shipping to Mo003 Lou Fusz Kia 1025 N. LINDBERGH BVLD. ST. LOUIS MO 63132
Thanks so much!!!
Showing In Transit to dealer with ETA of 08-11 as of today@StephenCantrelle can I get another update on 5XYP6DHC2NG206778? Thanks! Sending a venmo tip your way
DJ is attached... Showing In Transit with ETA of 08-25 as of today@StephenCantrelle Thanks for all you do! Would you mind tracking vin number 5XYP34HC3NG209147? Initials should be CJ or JJ, I believe.
ETA showing 08-10 as of today.. all I can see is when it goes In Transit from factory... currently Telluride is at factory@StephenCantrelle
The last ETA showed 8/10. It should have completed the final inspection on 7/31 and it is supposed to be "tendered, not shipped" tomorrow (8/4).
Then it is scheduled for "shipment out" on 8/6 (Friday).
On your end, are you able to see once it ships out? I have to make a trip to get the car....so trying to pinpoint within a day or so the date I can pick it up. I will reach out to my dealer towards the end of this week.
VIN 5XYP5DHC4NG209135 with initials JM
Winner Winner! Your name is attached.. ETA showing 08-20 as of today@StephenCantrelle Hi there, I've been following along in this forum for a while and finally got what I THINK is our VIN from Failcat. Could you check 5XYP5DHCXNG211875 and let me know if it's ours, and if so what the ETA is showing? Initials are AW.
Thanks! Tip sent.Winner Winner! Your name is attached.. ETA showing 08-20 as of today
Thank you!!Thanks! Tip sent.
In Transit to dealer... ETA showing 08-09 as of today... getting close!@StephenCantrelle can I get an update on 5XYP5DHC4NG205120 please? Should be getting close....Got a couple trips coming up so need to start planning the pick-up.
I don't know why, as the big day is approaching, I'm getting more jittery...I was fine in the beginning, and with a month to go...but now I think I'm gonna puke! Thanks for the update, it helps tremendously.In Transit to dealer... ETA showing 08-09 as of today... getting close!
Winner Winner.. CB is attached.. ETA showing 08-16 as of todayHi @StephenCantrelle. When you have a minute could you please check a VIN for me? I'm not sure if this is ours, but it matches our order description on failcat. Initials should be CB, or maybe KB.
5XYP3DHC5NG210624
