Multiple Safety Systems malfunction
BasilFawlty
New Mexico
Today I started getting multiple warnings in my Display. For example: "Check Front Avoidance Assist system", and "Check Lane Keeping Assist" (which seems to have stopped functioning) and also,
"Check high beam assist system".
Any ideas?
Any ideas?
How many miles on the car?
just under 23k.
Only guesses. Are there any error codes? They seem to be related. Brainstorming. Sensor obstruction of some kind? Dirt, mud, bugs, corroded connectors, broken wiring, fuse?
More likely, a visit to Kia service should be in order.
I didn’t check codes, but got those several warnings in the center screen. If I was going to hazard a guess it would be that the front “radar” sensor has gone bad. Kinda hoping someone here is a KIA tech, or knows one, who has seen this before.
Could also be defective 12V battery wreaking havoc on electrical systems. You should get your battery checked out as well. Good luck!
I will do that, thanks
Does anything show up when you run diagnostics? Any messages in the UVO app? Otherwise, perhaps better to get pics of the warnings, and take it in for service. With 23K, have you had your scheduled oil change, and checkup? If not, perfect time to take it to service.
Had it in today to have windshield washer line replaced (leaking from a crack). Tech noted the errors and suspects bad front camera. Has ordered a new camera. The front camera does work when you select “front view” from the switch behind the shifter, but still could be circuit in the camera that communicates with the other systems.
The front view you see on the head unit when using SVM is the camera below the front emblem on the grill.
The front camera used for FCA, LKA, and HBA is the one on the windshield behind the rear view mirror.
Yes, that is the camera they are replacing. I had been scheduled tomorrow to have it replaced but learned today that the camera in question is on back order. No ETA! Arghhgg!
My car is having the same issues 21 telluride EXP with 33,000 mi. Did you ever find a solution?
