- Mar 7, 2019
ETA showing 09-23 as of todayHey @StephenCantrelle can you check 5XYP5DHC9NG222110 again for me. Hoping for the date to have moved up some
I see different name attached on this one.. if you did a custom order this is not the one.. ETA showing 09-25 as of todayCan you please check to see if “ET” is associated with this order?
217424 5XYP6DHC0NG217424
ETA showing 09-23 as of today@StephenCantrelle Would you mind checking ETA on this 5XYP3DHC9NG222131 please? Is it still 09/19?
Sending you beer money...
Check with dealer.. showing in dealer stock!Hey @StephenCantrelle, do you mind tracking 5XYP5DHC8NG205556 once more for me please? Hoping it’s still on track for the 22nd! Sending another tip your way, thank you for all you do!
Winner Winner NG223587 has assigned AP(S)... ETA showing 10-29 as of todayHi Stephen, two different VIN's popped up yesterday at my dealer that match. Can you tell me which one, if any, are assigned to AP? Also eta for that order?
5XYP5DHC1NG223591 or 5XYP5DHCXNG223587
Your name is attached...ETA showing 09-23 as of todayHi, could you see if my ETA is still on track for 9/23? Thank you!
5XYP64HC0NG220971- initials TD
Showing in transit to dealer with ETA of 09-22 as of today@StephenCantrelle would you mind checking the ETA on 5XYP5DHC0NG215255 for me? Appreciate everything you do here! Thank you in advance.
Your name is attached... ETA showing 09-25 as of todayHi @StephenCantrelle could you please check VIN# 5XYP5DHC7NG221733, initials should be MK? Thank you for everything here!
Awesome. Dealer mentioned showing 9-15 as of today? Is that accurate? Has it shipped thanks for infoETA showing 09-18 as of today
Has not shipped out but once it does it will show in 24-48 hours since your close to me.. ETA showing 09-22 as of today.. that date will likely be sooner as it is just waiting to go In TransitAwesome. Dealer mentioned showing 9-15 as of today? Is that accurate? Has it shipped thanks for info
Showing In Transit to dealer with ETA of 09-29 as of today.. so holding ETA as of now@StephenCantrelle Would you mind checking 5XYP6DHCXNG219195 again for me? I think you said 9/29 last time, I've already booked my flight, just wondering if I need to move it. Or will it really just be the week of that I get a good update? I'm flying Southwest so easy enough to move my flight, just need to coordinate the PPF and ceramic I'm having done after delivery.
@StephenCantrelle When you say in transit, is that to mean it's actually loaded and on the way with some other stops on the way presumably? Or is it awaiting leaving the dock/factory?Showing In Transit to dealer with ETA of 09-29 as of today.. so holding ETA as of now
Any chance you could still see if this shows 9/23? Dealer keeps saying October. Thanks!BP is attached... ETA showing 09-23 as of today
Physically on its way to dealer.. either by truck or by rail and then truck@StephenCantrelle When you say in transit, is that to mean it's actually loaded and on the way with some other stops on the way presumably? Or is it awaiting leaving the dock/factory?
