Track my vehicle
Can you please check to see if “ET” is associated with this order?
I see different name attached on this one.. if you did a custom order this is not the one.. ETA showing 09-25 as of today
Hey @StephenCantrelle, do you mind tracking 5XYP5DHC8NG205556 once more for me please? Hoping it’s still on track for the 22nd! Sending another tip your way, thank you for all you do!
Check with dealer.. showing in dealer stock!
Hi Stephen, two different VIN's popped up yesterday at my dealer that match. Can you tell me which one, if any, are assigned to AP? Also eta for that order?
5XYP5DHC1NG223591 or 5XYP5DHCXNG223587
Winner Winner NG223587 has assigned AP(S)... ETA showing 10-29 as of today
Hi, could you see if my ETA is still on track for 9/23? Thank you!
5XYP64HC0NG220971- initials TD
Your name is attached...ETA showing 09-23 as of today
@StephenCantrelle would you mind checking the ETA on 5XYP5DHC0NG215255 for me? Appreciate everything you do here! Thank you in advance.
Showing in transit to dealer with ETA of 09-22 as of today
Awesome. Dealer mentioned showing 9-15 as of today? Is that accurate? Has it shipped thanks for info
Has not shipped out but once it does it will show in 24-48 hours since your close to me.. ETA showing 09-22 as of today.. that date will likely be sooner as it is just waiting to go In Transit
@StephenCantrelle Would you mind checking 5XYP6DHCXNG219195 again for me? I think you said 9/29 last time, I've already booked my flight, just wondering if I need to move it. Or will it really just be the week of that I get a good update? I'm flying Southwest so easy enough to move my flight, just need to coordinate the PPF and ceramic I'm having done after delivery.
Showing In Transit to dealer with ETA of 09-29 as of today.. so holding ETA as of now
Hi there @StephenCantrelle! Would you please check if there is an updated ETA to 5XYP5DHC2NG220182?
Hi @StephenCantrelle Could you check 5XYP5DHC3NG212902? It was a custom order so it should be under the initials RP. It popped up on failcat on 8/05 so I’m surprised it hasn’t arrived yet.
Thanks again for everything that you do!
@StephenCantrelle When you say in transit, is that to mean it's actually loaded and on the way with some other stops on the way presumably? Or is it awaiting leaving the dock/factory?
Physically on its way to dealer.. either by truck or by rail and then truck
