My odometer is at 4,200 on my Telluride S trim now. You can see (click on for more details) my overall Fuelly stats below. Typically, on highway trips, I'm getting about 26 mpg. I generally keep it at around 75-77 mph.Picking my Telluride up tomorrow! Curious what gas mileage you all are actually getting versus what’s on the window sticker. If AWD, what mode are you driving in? Thanks!
Your 27 mpg is almost exactly the same as I got (mine was 28 mpg) on a recent 1,800-mile trip from Missouri to Washington state when traveling at 65-75 mph. However, as expected that went down when I set the cruise at 90 mph through parts of Montana on Interstate 90 which has a posted speed limit of 80 mph. It went down to about 20-22 mpg at those speeds.While some put way more miles than I did on a trip, he’s my one-way so far in the Pacific Northwest. I have a 22’ AWD SXP NF/T Telluride. Most of the drive was highway speeds varying from 55-75mph, with minimal slow traffic around 10-25mph. I had a about 2 pedal to the floor moments but mostly kept the vehicle in adaptive cruise with eco mode. The onboard logic estimates 27mpg. I’ll do the hand math when refuel and plus monitor the mpg on my way back on the return trip.
Thanks and really good point. I do the same and on my first tank (I've only filled up onceIMO, there are two types of fuel economy, those reported from the dash display (I call it the lie-o-meter) and those taken by comparing actual fuel purchased versus miles driven.
I got over 24 MPG out of my first tank of gas (fuel purchased versus miles driven), which was a pleasant surprise for me.
So after a second fill up which had a lot more highway driving, the computer estimate was about 1.1 MPG higher than what I actually got based off of gallons used. So maybe highways miles do cause a slightly overestimate? Although obviously need more than one tank to confirm.Thanks and really good point. I do the same and on my first tank (I've only filled up once) - the two calcs were within 0.2 MPG assuming Kia filled the tank and didn't top-off. Will track going forward for sure and report back if actual vs. computer vary significantly.
For reference, can I ask how much of difference you're seeing?
Which app?Just FYI for those watching mileage. I find that the mileage on the display is a little "optimistic". I keep track of my actual gas usage and miles with an app, and my actual mileage always lags behind the car's display a bit.
Same here. I've been using Fuelly and I'm usually a couple MPGs lower than what the car tells me.Just FYI for those watching mileage. I find that the mileage on the display is a little "optimistic". I keep track of my actual gas usage and miles with an app, and my actual mileage always lags behind the car's display a bit.
I'm using My Car, which also tracks oil changes and other maintenance, but there are many other free apps that work well.Which app?
Doing about 60/40 Highway / City and using mostly Eco mode, I average 24-25mpg
