Track my vehicle
Good Morning,
New to this forum but have read through some of the threads.
Ordered 2022 Sangria AWD EX on 10/1 (through a dealer I found on this site) at MSRP. I was told by dealer that they could see the MSRP Sticker created in the system. At what point in the process does this happen? Thanks!
When the Telluride has started the building process at factory. That is when a Monroney Sticker is generated
Hello,
Can you please check ETA on my Vin # 5XYP3DHC9NG238815.
Thank you so much!
ETA showing 12-05 as of today
@StephenCantrelle Hi, can you track this VIN? I purchased an incoming vehicle and I believe this one is mine. VIN #
5XYP3DHC1NG234080. Thank you I'll be sure to leave something in your Venmo.
Showing In Transit to dealer with ETA of 11-21 as of today.. Thank you for the Venmo!
@StephenCantrelle when you have moment can you please check on ETA for 5XYP3DHC8NG239017?
ETA showing 11-28 as of today
Can an order be modified by the dealer if the order has not been picked up by KFOS? If it is modified does it have to go "to the back of the line"?
Thanks for any input!
What exactly are you changing. For port installed options shouldn't be an issue. If changing color or trim package then yes that would be a new order and therefore put at back of line.
Hi @StephenCantrelle could you please check the ETA on VIN#: 5XYP3DHC9NG234893 Thanks!
Showing In Transit to dealer with ETA of 11-26 as of today
Thank you! Is it in transit or is it yet to be shipped?
I always specify when in transit that it is.. so this one is not yet in transit
