Beeping randomly after it has been shut off
JoeinPSL
So my 2020 (with 22,000 miles) has started to beep in the garage every few minutes or so. I don't mean the horn, just the little musical beep. I checked all of the doors, went through the configuration screen, started it and stopped it a few times and nothing works. Anyone else have this problem or know how to fix it?
Can you record a clip of it and post? Will need to upload to a third party site like youtube/vimeo/dropbox, then post the link.
Does it sound like the door lock sound, or the long beep when you leave the car running and walk away? Besides those two sounds, I’ve never heard any other sounds from outside the car.
Are you sure the sound isn’t coming from something else in your garage? Or did you have any aftermarket devices installed on your car that could be making a noise? Something you might have left in the trunk that makes sounds?
Thanks! I took both cars out of the garage and it ended up being the battery back-up in my garage door opener.
Mine is doing the same thing! Can’t figure it out.
I’m also having the same issue - I have a 2022 - just a random as if you like the door beep then stops - all day random
My 2022 has started the garage beep now. Every 30 seconds. Anyone figured this out?
