The weephole in the filter's plastic housing will seem to leak oil! This could be caused by residual oil. Or could be due to filter's sealing mechanism (or lack thereof). I noticed this twice already after changing the oil. More importantly--how to make sure the filter cap's O-ring is properly seated. Next is how tight is tight when closing the filter housing? When I first change the oil (1,700 miles), I marked the cap with a Sharpie line aligning this to the weephole before I opened the filter housing. After the oil change, I closed the filter housing by making sure that when I made the last twist, the Sharpie line on the cap was aligned with the weephole. Then I tighten the filter cap just a little bit more (Sharpie line passing the weephole just a few mm) but being careful not to over tighten it to avoid cracking it. Aside from being short 1.5 quarts of oil when I measured what I got out at yesterday's oil change (after 3.500 miles), I didn't find anything more alarming--leak, drips, or any sign of oil on the floor--I always look for oil leak (an old habit). Oh, I also noticed being short of 1 quart at 1,700 oil change, btw. The skid plate had no oil residue or stain when I inspected it during the oil change. But yeah, there seemed a leak or seepage coming from the weephole right after the oil change. This could be "residual oil that drips to the weephole"--if in a very small and limited amount! Next time, I have to remember the "quick wipe"! Or a true leak due to wrong O-ring seating. Or improperly torqued oil filter housing cap. This is easy to see because the leak will be undeniable--oil drips right away! But TBH, I never torqued! Thanks.
