How to have interior lights on when opening door?
DCTellEX
Man this is so basic, but I figured I'd ask this crew. When I go to my car at night, I unlock it and open the door... it's total blackness inside. What do I need to do so that the interior lights pop on? Thanks a ton.
Depress the light button (not the light itself) on passenger side of the center roof console.
Sorry, that is pretty non-descriptive, but I can't come up with a better way of saying it.
Press the button labeled "2" (door mode). (page 4-129/4-130 of the owner's manual)
The map lamp and room lamp come on when a door is opened.
The lamps go out after approximately 30 seconds.
- The map lamp and room lamp come on for approximately 30 seconds when doors are unlocked with a smart key as long as the doors are not opened.
- The map lamp and room lamp will stay on for approximately 20 minutes if a door is opened with the ENGINE START/STOP button in the ACC or OFF position.
- The map lamp and room lamp will stay on continuously if the door is opened with the ENGINE START/STOP button in the ON
position.
- The map lamp and room lamp will go out immediately if the ENGINE START/STOP button is
changed to the ON position or all doors are locked.
- To turn off the DOOR mode, press the DOOR button (2) once again (not pressed).
position.
awesome thanks a ton. I must have hit it by accident at some point. I'm used to older school cars with the center sliding switch that basically has on, off, and door mode (though I didn't know it was called that).
You're not alone. My car came like this from the factory and I had to turn it on when I got it.
You are now my new best friend! Thanks so much, even though you were answering me.
thechief16, post:
OMG THANK YOU!!!
Thank you so much!!! Since time change. This blackness driving me crazy and tried everything!
position.
Thank you very much for the clear description. I love my 2023 Telluride, but it seems like the simplest things are the hardest to find information about how they work.
THANK YOU! It was driving me crazy!
2022 Telluride - Interior lighting was working fine. I must’ve hit the “light button” by mistake and changed it where the interior was dark when I opened the car doors. I also thank you for your answer. :-)
Thank you very much. worked fine
