A/C seats for non only heated seats and console wireless charging for non wireless charging
Chchoe78
I asked the technician that was working on my Telly S if it’s possible to add the a/c to the seats. He said that the seats have there own vents and you could just buy the OEM seats with the air vents installed. Has anyone else heard anything about this?
In addition, I asked if I installed a wireless charger on the inside of the center console would void my warranty and he said no, that should be fine. I saw someone already put a wrap on the center console and they said it was easy. Anyone hear if this would void your warranty?
Anyone else interested on these mods?
I put a black neoprene wrap I got from Amazon on my center console, which can be removed at any time since it has elastic. Warranty would not come into play.
The seats do not come with A/C at all. They are ventilated which means they recirculate the cabin air through you seats.
Adding an aftermarket product does not void a warranty. The aftermarket, non-stock for your model product, will not have a warranty for your vehicle from KIA. If the aftermarket product causes something else to fail, then that failure itself might not be covered. KIA must prove your wireless charger caused something else to fail, which in this case it is highly unlikely.
2515
Aftermarket charger added --------Place the phone and charging now
:love:
Great work...
1. Where did you pace the wireless charger. Under the center console or on top?
2. Or did you place it under the center console? Also did you use one of the USB ports or did you tap the power from inside of the center console?
I was looking to place the charger on the bottom of center console and tap the power from underneath the center console. Thanks again for sharing.
If we are all thinking the same. Then no one is thinking.
Also can anyone provide pics of the bottom of there seats who have A/C seats? I was thinking of possibility using my 3D printer and make a Y connection to see if I can add on to lower floor vents to shoot up to the seats. Something small enough to remove. Due to the fact, this would mean that your A/C and heater lower floor vents would be the main controller for this option. Rather than having it on a standalone controller. Thoughts?
Where can I find a center console wrap? What's a called or part number
I would buy it on eBay or amazon. You have to wrap it custom.
