- Mar 7, 2019
Usually, 24-72 hours depending on if it is the weekend or notI assume it doesn’t take long to ship to Fort Worth
ETA showing 11-21 as of today
Is invoicing the point it shows on the website?Usually, 24-72 hours depending on if it is the weekend or not
Typically, yes. It is after the build and inspection is done and is just waiting for transport.Is invoicing the point it shows on the website?
Thanks man - I appreciate youTypically, yes. It is after the build and inspection is done and is just waiting for transport.
Thanks Stephen! Hopefully the first Vin I had you check on comes in first 11/13.ETA showing 11-21 as of today
Quick follow up to this…at what point can a typical dealer see an incoming VIN in the dealer system? Same time as it hits Failcat?Typically, yes. It is after the build and inspection is done and is just waiting for transport.
Failcat is a trailing indicatorQuick follow up to this…at what point can a typical dealer see an incoming VIN in the dealer system? Same time as it hits Failcat?
				 tellurideforum.org
					tellurideforum.org
				Showing In Dealer Stock on my end.. Check with dealer to see if it arrived yesterday/this morning@StephenCantrelle can you please check VIN 5XYP6DGC7PG338696
ETA showing 11-09 as of todayHello Stephen, can you check this VIN please?
5XYP5DGC9PG338458
