Leahray
- Nov 22, 2022
Ok at least it hasn’t been pushed. Thank youShowing In Transit to dealer with ETA of 12-12 as of today
thank you @StephenCantrelleWas a good day off... thank you. Showing in Transit to dealer with ETA of 12-10 as of today.
Showing In Transit to dealer with ETA of 12-15 as of today. Likely is going via rail and has to be unloaded at a rail yard before lining up truck transportGood Morning, Stephen!
I would truly appreciate it if you could look up our Telluride vin# 5XYP5DGCXPG338114. The dealer says December 15th, but it’s 3hrs away and we are confused at why the final miles to transfer it here would take almost 2weeks.
Thank you for checking if you are able.
ETA showing 01-03 as of today
Showing the same on my end... 12-20 ETA as of today. many factors can contribute to multiple delays. Finding something on final inspection stage where a part needs to be changed out and logistics with transport, are the two most common things that can cause delaysWell, my dealer is telling me that the ETA for my vehicle (5XYP5DGC9PG340632) has been delayed AGAIN. They say the new ETA is 12/20, but it was originally supposed to be mid November, then the end of November, then today, and now the 20th.
What could cause these kinds of shifts? Am I getting the whole story? Is this typical? Thanks for any insight.
Showing In Transit to dealer with ETA of 12-15 as of todayHowdy @StephenCantrelle hoping you could check on my Vin 5XYP3DGC6PG340108 I was informed it was delayed by a week which is fine just wanted to make sure I'm getting clear data. Thank you!
Showing In Transit to dealer with ETA of 12-12 as of todayOnce more?
Can you check on this?
5XYP5DGC5PG338361
ETA showing 12-17 as of today.@StephenCantrelle. Can you give an update for VIN 5XYP5DGC2PG347566 . Hopefully this will be the last update needed. lol.
Showing In Transit to dealer with ETA of 12-21 as of todayStephen, could you check the status of my vehicle for me?
Vin # is 5XYP5DGCAPG346595
