LED Warning Light Message
JRusk
I have a brand new Telluride Prestige package with less than a thousand miles. I have been getting this message sporadically since I purchased the vehicle last month. Took it to the dealer with photos. They said there's nothing showing up in the diagnostics. Anyone else experiencing this? Any clue on how to stop this message?
Thanks!
Thanks!
Very strange and unfortunate. I think you need to push the dealer to look at replacing the headlight LED assembly. I'm sure either you or the dealer can contact Kia and show the situation with the pictures. It's not normal and you shouldn't have to deal with it.
Also - as I reflect on this a bit more, seems like it may be either a loose wiring connection or bad fuse/fuse connection - given that it's intermittent. I don't have my Telly yet, but I would suggest looking at the back of the headlamp assembly and see where the wire connections are - try to remove and then reattach - see if that helps. I'd also check the headlamp fuse - pull/inspect and replace. Those are fairly easy items to check and may resolve the issue.
When that message appears, does the headlight stop working? or does everything work as it should but your getting that message on the dash?
It only appears on the dash. The headlamps are still working. The dealership said ignore the messages.
Thanks!
Welcome. This topic has been moved out of the community lounge and into the Telluride technology forum...
I'm having the same issue! Did you ever fix it?
