Sound Zones
eiskafee
After May 2023 Software Update, I only see 4 audio zones rather than 6 I used to see in last version. Now I am unable to enable audio in ONLY the 3rd row (Which was extremely useful for playing kids music). Anyone has same issue or a solution? Thank you
This is exactly what it has looked like since the fall 2021 version.
Several versions earlier than that only had sliders, you couldn’t even just tap on an area.
This would work basically just as before… if you have it set up as it is in your screenshot, just push the down arrow until it won’t go any further toward the back of the vehicle. That should fade the sound all the way to the back.
(Although I did try this when I got out to my car… even when at the max of R 10, it would still play from second and third row speakers [only eliminating the fronts]. Not sure if this differs from before since I’ve never moved my sound all the way to the back before [centered is optimal for me].)
