Climate control behavior in a '24 SX-P.
irishbrahmin
Indiana
I have a '24 Telluride SX-Prestige that I've owned for about 3 weeks. When I have the climate system set on AUTO, the air intake always starts in recirc mode and stays there. If I switch to fresh air, it'll revert to recirc when I restart the car. If I crack the sunroof, the intake will switch to fresh air. Is this behavior normal? The temps around here have been between 70-95 degrees and it's been pretty humid. Thanks!
Sounds normal - I am pretty mine does the same. As far as I know, and unlike some other things in the car, you cannot pre-set Climate Control to be the same every time you start the car.
