Sirius Preset Question - toggling through includes AM/FM/XM1?
KiaJohn
Ohio
Hi Al,
I have my Sirius XM Presets all set up and I use the steering wheel toggle switch to move up and down. However when I do that, it also includes AM/FM/Sirius Channel 1 Preview.
Is there a way to only have Sirius preset channels to toggle through? It works this way on my Genesis with a separate button if I wanted to get to AM or FM presets.
Is there a setting I am missing to be able to just toggle through my Sirius presets?
Thanks, John
Hi Al,
Thanks, John
The steering wheel toggle will cycle through your presets exactly as shown on the screen. So if you have a mixture of AM, FM, and SXM, it’ll go between the bands based on the preset order you’ve chosen.
You can always reorder your presets if you want them to be in a different order. But you can’t lock out a certain band when you’re cycling presets like this.
Thank you,
Can I hide the AM?FM/Sirius Channel 1? Or another way to move between presets?
Thank you,
If they are stations you don’t want as favorites, remove them from your presets list.
I must be looking at it wrong because the AM and FM don't appear at Presets for me to hide.
I found it!! I had to go to Delete Presets and I found the AM, FM, and SXM 1.
Thank you!!
