- Mar 7, 2019
Showing In Transit to dealer with ETA of 09-02 as of todayHi Stephen, may I ask you to track 5XYP5DGC8RG434827 for me?
Thank you!
R
Thank you!
R
Showing in dealer stock on my end. Check with dealer as they may have got today.Please track 5XYK53DF5RG139140
Thank you!
Showing In Transit with ETA of 09-04 as of todayCould you track 5XYP5DGCXRG429483?
Showing in dealer stock. Check with dealer as may have showed todayHi Stephen - mind taking a look at 5XYP5DGC8RG436710 when you get a second? Thank you!
Showing is at Port. ETA showing 09-08 as of today.Hopefully the last time I need to ask. Could you track KNDPXCAG6P7079649?
Thanks so much. I sent you a venmo for all the help.
Is it normal to be in port and delayed so many times? The original date was the end of JulyShowing is at Port. ETA showing 09-08 as of today.
Thank you for the Venmo!!
It does happen, I have seen before that the port inspection could have caught something that needed to be replaced/changed out. Also could be a recall they take care of at port.Is it normal to be in port and delayed so many times? The original date was the end of July
That is interesting. Thank you!It does happen, I have seen before that the port inspection could have caught something that needed to be replaced/changed out. Also could be a recall they take care of at port.
Many factors may occur to cause the delay. The car is not yet Invoiced which takes place right before car goes In Transit from port to the store.
Currently At sea... ETA showing 10-26 as of today
If you can provide VIN I can check on latest ETA for youDoes anyone know if the hurricane is or has affected delivery times/dates? My dealer told me last week that mine should arrive tomorrow!
Sure - It will be appreciatedIf you can provide VIN I can check on latest ETA for you
Still at factory at the moment. Just waiting for transport. ETA showing 09-08 as of todaySure - It will be appreciated5XYP5DGC0RG437933
