Yet Another H/K System Upgrade
HLXHLX
NatCap
Yes, this is just another owner’s take on the forum-polarizing topic of upgrading their Harman Kardon “Premium” sound system. My personal journey inspired by actual events…
Who: Me. A 2023 Telly SX owner since October 2022. I love music and the experience of both listening and feeling it, especially while driving when the only alternative is talking with my family. I have kids who love music, too. I also have kids whose eventual screaming matches need a good drowning out from time-to-time.
What: The Harman Kardon, 630-watt, 12-speaker, 11-channel, factory-EQ’d sound system. Always gotta be a bit cautiously optimistic with stereo systems in mainstream vehicles, especially those tagged with a “premium” label. I chose the SX trim for all the other bells and whistles, so with that the H/K system was the only option.
Why: For me this H/K system just did not deliver what I enjoy about music. Up to about volume level 50 (~66% max), it’s decent. It was well-balanced, full and therefore probably meets the acceptance of the vast majority of owners. However at volume level 50 it just still wasn’t very loud or powerful and I could definitely hear the low end really start to taper off when pushing it further, not to mention the factory EQ-ing and processing becoming more apparent. So it was right there at those entry listening volumes where the H/K really fell apart for me.
Solution: An upgrade. Being my family hauler I wanted any upgrade to be as minimally impactful to the space and functionality of the vehicle as possible. That decided, I was limited to space under seats and in the rear storage compartment. Also didn’t want to reach too far into my wallet, so any holiday sales and scratch & dent deals were prioritized (Crutchfield (y)).
Plan:
  • Upgrade #1: Speakers. I knew from the start that replicating the 11 H/K channels was not an option. The center and 2x surround channels were of little added value. And the sub, well…it tries for a bit. By that assessment I knew I would target the doors and sub, all of which could certainly outperform any artificial presets for soundstaging and general overall performance. A prime example of quality > quantity. Seeing in these forums the difficulty of pushing new speaker wire out thru those door connectors, I chose to stick with the stock wiring and go with passive x-overs and components, similar to the stock setup in the rear doors (2x speakers/channel vs. 1x speaker/ch in front). IMO components outperform coaxials, and the Telly is already designed for components with those stock locations. I ended up going with Polk speakers, x-over mounted and wired all within each door.
  • Upgrade #2: DSP/amp. By my remedial math, 5 output channels is what I needed; 1ch to each door and a 5th for a new sub. DSP…yes. The H/K amp doesn’t just amplify, it also does a ton of processing without a lot of user control other than a 3-band EQ in the H/U. Considering my minimal space impact I chose to go with the Audio Control D-4.800 amp/DSP combo unit. Why? Size: small; Power: big (125w/ch RMS); accepts amplified hi-level inputs; built-in DSP providing full customization (x-over, time alignment, 30-band EQ, signal summing). Although only 4 channels, this unit does have one low-level output, perfect to feed a…
  • Upgrade #3: Powered subwoofer. The factory sub has nothing to give at higher volumes which makes music sound empty and unbalanced without those low-end frequencies. Again considering space, I went with the Kicker 46HS10 (180w RMS) which fits wonderfully in the rear cargo compartment. Neighborhood-shattering…no. Does it complete the music with power, depth and balance…absolutely.
Install:
  • The 6.5” Polk’s were basically a direct switch with the stocks. Drilled one little vertical hole to pass the woofer wire from behind the inner door panel. Passive x-overs fit just fine on the inner door panel with some Gorilla tape and #6 bolt+nut. The stock tweeters are built into a plastic bracket, so for the Polk’s I used #8 screws in the stock door holes with the tweets mounted to a thin piece of aluminum; using multiple nuts you can adjust the installation heights to match the offset angles on the door. Respective wires routed to the x-over with the stock woofer wire; secured neatly with Tesa tape. In the front doors, the stock tweeter wire is now unused.
  • The D-4.800 went under the driver’s seat; it’s quite small and should not interfere with (or by) kid or adult feet. This location was ideal as it’s in close proximity to the H/K amp to pull signal and push back out to speakers along with being on the same side as the battery for powering. I used 4 gauge directly from the battery, passed thru the firewall in the footwell area and routed down under the floor side trim. Used a weather-sealed grommet and zip-ties throughout. Made a simple bracket and mounted the fuse right in front of the battery. Since I wanted to utilize the stock speaker wiring, I had to find a way to both grab the amplified H/K signal for the D-4.800 and send its new signal back out to the speakers. For that I made a breakout harness that inserts between the vehicle connector and into the H/K amp, permitting me to do so without cutting any factory wiring. Since there wasn’t much slack available from the factory connections, I re-mounted the H/K amp about two inches closer to the door to create some breathing room for the new wiring. Two runs of speed wire between the driver and passenger seats was all I needed to make the needed signal/speaker connections; removal of both seats and center console were ideal to making it clean, direct and secure, and didn’t wind up being nearly as challenging as I anticipated.
  • The Kicker sits nicely on the driver's side in the cargo compartment. Powered directly from the battery with similar installation and wire routing as the D-4.800. One pair of RCAs and a single trigger wire from the D-4.800 was all else it required. Although far from an ideal sub enclosure, the cargo compartment does “port” thru the stock sub location and doesn’t seem limited by the rigid cargo cover plus mat. For me those sub freq are prob more about the feel than they are the direct sound.
  • Additionally, I did replace the stock battery ground wire with 0-AWG.
Setup:
  • The DSP is certainly the brains of this operation (more-so than me) and where all these upgrades come together. The factory EQ, corrected. The factory bass roll-off, gone. The ability to customize the sound however I choose, available. With this setup all other voice and navigation features are completely retained which was critical as I use them every day.
  • Prior to my final install I did take a look at what the factory signals looked like and decided to utilize the front woofer and tweeter channels for primary sound; although the rear signal didn’t offer anything additional than those fronts, I did use them to retain music playing during voice nav prompts (fronts set to auto-mute in H/U). In the DSP I summed those four front and two rear channels, set a high pass and now use that summed signal to drive both the front and rear doors. The sub receives only the front woofer signal with a low pass. Again with this particular setup I retained H/U volume control and balance, but not fade. However, what I also really like about the D-4.800 is its ability to store multiple configuration presets: with the Audio Control remote (mounted in the fuse panel) I have the ability to change those presets for a particular driving scenario. Primarily, I’ll have all speakers on, but on road trips when the kids are passed out I can easily change to a preset that has no sound in the rear speakers (effectively a fade). I also have that same remote linked to control the sub volume so it can be adjusted as needed.
Conclusion: Totally biased here.... These upgrades perform excellent and have given me the sound system in the Telly that I wanted. A vast improvement over stock and done so within a reasonable budget. I have retained all audio functionality, albeit with some new methods to do so. Will now be enjoying this ride even more until I trade it in for a ‘24 later this year (simply because of the amber DRLs). 😎
D-4.800 install:
H/K amp breakout harness:
*Pre- soldering to speed wire.
D-4.800 fuse:
Sub fuse:
Firewall:
Sub install:
D-4.800 remote:
H/K Front woofer signal:
H/K Front tweeter signal:
H/K Rear channel signal:
*Kinda confused by this one as it drives both the woofer and tweeter, but nothing much on the high side??? The front woofer channel looks more appropriate for the rear setup. 🤔
Plan:
Install:
Setup:
D-4.800 install:
D-4.800 fuse:
Sub fuse:
Firewall:
Sub install:
D-4.800 remote:
Awesome!!!
Thanks for the detailed pics. Super helpful. I'm actually going to be running an amp over the weekend. Did you drill a fresh hole for the power wire for the amp?
Yes. In my Firewall pic above (it's rotated) the sub power wire (12awg) is the smaller of the two white cable glands. I used a step bit and it took maybe 30secs to create a clean edge at the exact size needed.
Going to use this setup as a guide. Can you recommend a cheaper DSP/AMP combo? Would the Sony XM-GS6DSP work as a fill in? I am on a bit of a budget. Going to start with the DSP/AMP and the powered sub, then finally the speakers.
Kicker Key 200.4 amp/dsp combo. I just installed one, and it's awesome for sub $300. It's more than good enough for me, with my upgraded front speakers too.
Kicker Key 200.4
Thanks for the recommendation! Thats more in line with what I want to spend, did you try it with the stock speakers first? If so where they the regular or HK? I was going to see what would happen with more power through the stocks plus a powered sub. Obviously, not expecting much and will do the door speakers eventually.
No, I had my upgraded speakers first, then added this in afterward. As expected, the stock radio just can't cut it! The Key really made a night and day difference. I have heard that stock speakers can come to life with this thing. It's worth shot. Then add better speakers later if the Key doesn't meet your expectations.
The Key really brought my upgraded speakers to life. I added my Focal speakers first and the stock amp simply didn't meet my expectations. Adding the Key, the image really came to life and the whole system simply woke up. I think adding the Key is probably your best bang for the buck. If it doesn't sound good enough, upgrade your speakers and justice rerun the tuning setup which takes just a few minutes.
Me thinks any upgrade to the H/K system is an improvement :cool:
Does this retain ALL volume functionality? Such as steering wheel controls etc. what would be the best route if I wanted to retain that? Will upgrading the speakers and adding a powered sub under the seat or in trunk be an upgrade over the factory system?
In my setup all HU/SW functionality is retained EXCEPT for fade control, though that can still be adjusted via the DSP. May not be the same for other more advanced upgraded systems found throughout these forums.
I believe the forum consensus is that the addition of any mid-level or above aftermarket audio components to the stock base or H/K systems provides an appreciable performance improvement.
Thanks for the clarification. So does your amp use the H/K amp as a pre-amp? Do all channels go from the head unit, through the H/K amp, new amp and then to the speakers? If so, where have you tapped into the wiring?
With the H/K system the amp also does all the processing from the HU (unlike the base/non-H/K audio system), so that did remain as a "pre-amp" for processing and HU/SW controls. Make sure your aftermarket amp can accept amplified inputs. You can find a couple other more complex H/K upgrades that completely bypass the stock amp with other aftermarket components.
Per my initial post, I used only the front (woofs + tweets) and rear door channels to sum a more "complete" pair of L/R channels. Look at the stock signal pics up top. I don't use the center or sub channels and the rear surrounds are still powered from the H/K amp (needed timing adjustment in new DSP). I built a breakout harness for the H/K amp that I used for soldered connections instead of tapping factory wiring.
Ok, that makes sense. This post has inspired me to take on an upgrade. I have seen other posts as well but always $3k+ budgets for parts alone so had to look the other way.
- Did you do anything in terms of sound insulation / deadening? in the doors or trunk area?
- You integrated the amp knob very clean inside the fuse box holder. What does that knob do exactly? Is that "volume" for the amp? How does that work with the volume on the head unit/ or steering wheel?
- Speaking of knobs, I noticed you left the sub knob attached to the unit and chose not to bring that over by the driver seat for easy access. Is there a specific reason to that? Do you find yourself needing to adjust bass between songs?
I did minimal deadening...only a small sheet or two per door about as far as I could reach my arm in the speaker opening. Did not also want to undertake removal of the inner door panels for complete access. Maybe a future project for me.
The knob in the fuse door is the remote for my Audio Control DSP/Amp and it can be linked to two functions in the DSP. I chose to use it as a sub volume control and as a preset selector. For that reason I did not need the aftermarket sub remote and just left it on the unit at ~90% max volume. My presets basically function as fade controls.
Great tip! I’m going to make an appointment to get a quote for installation from 2-3 local shops next week. I could see myself tackling the sound deadening but the installation seems a bit over my head. Especially the breakout harness and tuning the DSP parts.
One more thing I wanted to ask you. That powered sub looks very compact and possibly slide under the passenger seat. Did you consider that as a location? Curious how you ended up with the trunk location? Thank you.
No. The H/K amp is under the passenger seat while I installed the new DSP under the drivers seat, so in addition to the floor air vent there just wasn't enough real estate for the compact sub as well. It's got some breathing room in the cargo bin while permitting easy access if needed. Check out this guy's under-seat sub install in a similar Palisade.
